op music
#1 Posted : Friday, May 1, 2015 8:55:45 AM(UTC)
op music
Hi, I have a card Aja Xena Lhe win 8 works with WMIX? thanks
op music
#2 Posted : Friday, May 1, 2015 9:00:59 AM(UTC)
op music
I apologize the card is installed on the PC, but in Vmix not see, thanks
op music
#3 Posted : Friday, May 1, 2015 10:29:45 AM(UTC)
op music
Hi, I just installed on a PC with windows 7 but Vmix does not recognize it, can anyone help? maybe there volgiono other driver? I installed the drivers from AJA. thanks
ericn
#4 Posted : Saturday, May 2, 2015 5:36:08 PM(UTC)
ericn
The current Kona Lhe Plus model would, however the the XENA/KONA LHe is no longer supported by our current driver package (12.x) that vMIx has implemented support for.
Kona Lhi, Kona 3G, Kona Lhe+, Kona 4, IoExpress, IoXT and Io4k do all support the driver versions that work great in vMIx.
op music
#5 Posted : Thursday, May 7, 2015 8:12:51 AM(UTC)
op music
thanks for answering, so I can not install the new version of Vmix? thanks
ericn
#6 Posted : Thursday, May 7, 2015 12:15:05 PM(UTC)
ericn
vmix should work just fine, :) the Xena card just wont work in vMix because it is one of our older cards that doe not run on drivers that vMix supports.
Guest (6)
Similar Topics
AJA Xena LHe PCIe HD Card (Hardware Compatibility)
by cslavinskas 11/12/2013 3:32:48 PM(UTC)
