coskel22
#1 Posted : Wednesday, April 15, 2015 10:12:45 AM(UTC)
coskel22
I trird recording files using the recommended TS extension for editing.
When I try to import, PP 5.0 returns File format not supported.
Using on the same PC it was recorded on.
#2 Posted : Wednesday, April 15, 2015 8:41:46 PM(UTC)
@ coskel22
Premiere Pro CS5 does not like .ts files.
Rename the file and change the extension to .mpg and it should work fine.
This was discussed earlier, but I take it you already knew that...
http://forums.vmix.com.a....aspx?g=posts&t=2667
Perhaps this is a new development in vMix 15, I do not know.
I have refrained from recording to anything but .avi of late just to avoid any hiccups with PP.
coskel22
#3 Posted : Friday, April 17, 2015 6:26:49 AM(UTC)
coskel22
I couldn't find that old thread, I thought that I had written about it before.
avi sure does eat up a ton of storage space, but you're right its probably the best option.
