.TS files no longer work in Premiere Pro
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
I trird recording files using the recommended TS extension for editing. When I try to import, PP 5.0 returns File format not supported.
Using on the same PC it was recorded on.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ coskel22 Premiere Pro CS5 does not like .ts files. Rename the file and change the extension to .mpg and it should work fine. This was discussed earlier, but I take it you already knew that... http://forums.vmix.com.a....aspx?g=posts&t=2667Perhaps this is a new development in vMix 15, I do not know. I have refrained from recording to anything but .avi of late just to avoid any hiccups with PP. Ice
I couldn't find that old thread, I thought that I had written about it before.
avi sure does eat up a ton of storage space, but you're right its probably the best option.
