op music
#1 Posted : Saturday, April 11, 2015 3:56:50 AM(UTC)
op music
Hi, I would ask if you can record excluding the overlay there is a way to do it? Thank You
richardgatarski
#2 Posted: : Saturday, April 11, 2015 1:17:38 PM(UTC)
richardgatarski
Of course there is.
In Settings/Outputs untick the overlays you do not want to be recorded.
Have fun!
op music
#3 Posted : Sunday, April 12, 2015 6:28:23 AM(UTC)
op music
hi, I know that you can do in the settings, but I want to send ONLY in output and not recording them in, but I did not go there in rec it in output I Vmix sd. Thank You
richardgatarski
#4 Posted : Sunday, April 12, 2015 10:32:19 AM(UTC)
richardgatarski
One of us must be misunderstanding the other.
If you want to Output something, with an Overlay in that Output, and Record that Output BUT without the Overlay.
Then go to Settings/Outputs, select Output under Record/External, and untick the overlays you do not want.
See attached image (trust me, the recording do not contain the Overlay shown in Output).
richardgatarski attached the following image(s):
