record excluding the overlay
Hi, I would ask if you can record excluding the overlay there is a way to do it? Thank You
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Of course there is. In Settings/Outputs untick the overlays you do not want to be recorded. Have fun!
hi, I know that you can do in the settings, but I want to send ONLY in output and not recording them in, but I did not go there in rec it in output I Vmix sd. Thank You
One of us must be misunderstanding the other. If you want to Output something, with an Overlay in that Output, and Record that Output BUT without the Overlay. Then go to Settings/Outputs, select Output under Record/External, and untick the overlays you do not want. See attached image (trust me, the recording do not contain the Overlay shown in Output). richardgatarski attached the following image(s):  vMix-unrecorded-overlay.jpg (302kb) downloaded 27 time(s).You cannot view/download attachments. Try to login or register.
