jbmusic
#1 Posted : Wednesday, March 25, 2015 6:24:08 PM(UTC)
jbmusic
Hi There.
I am not sure if I am putting this question on the right-chapter of this forum, but I am sorry if not.
For the moment I spend already a lot of time on the issue, that I would like to put OBS as a source in vMix.
I have seen that there is an option to add a input with the RTPM code but which code I should use, there I would like to use external sources true network / lan / internet.
This to add webcams to our network to make a sort of visual radio system and we have several DJ's on locations / live sets
Is there a way I could easily do this job or do I need to install an extra media server?
Mann thanks in advance for your help!
richardgatarski
#2 Posted : Tuesday, March 31, 2015 5:20:03 AM(UTC)
richardgatarski
I don't now enought of what OBS can stream. But I think it is aimed to stream to a streaming server. And because vMix cannot act as such, you can't stream from OBS to vMix.
One alternative is to install a server, eg as discussed in http://forums.vmix.com.a....aspx?g=posts&t=2687
Another one is to use an(expensive) encoder, such as the Teradek Cube. I would not be surprised if less expensive alternatives will be announced at NAB in a couple of weeks.
