Hi There.
I am not sure if I am putting this question on the right-chapter of this forum, but I am sorry if not. For the moment I spend already a lot of time on the issue, that I would like to put OBS as a source in vMix. I have seen that there is an option to add a input with the RTPM code but which code I should use, there I would like to use external sources true network / lan / internet. This to add webcams to our network to make a sort of visual radio system and we have several DJ's on locations / live sets Is there a way I could easily do this job or do I need to install an extra media server?
Mann thanks in advance for your help!
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
I don't now enought of what OBS can stream. But I think it is aimed to stream to a streaming server. And because vMix cannot act as such, you can't stream from OBS to vMix. One alternative is to install a server, eg as discussed in http://forums.vmix.com.a....aspx?g=posts&t=2687Another one is to use an(expensive) encoder, such as the Teradek Cube. I would not be surprised if less expensive alternatives will be announced at NAB in a couple of weeks.
