Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
Is there any limitation for the number of RTSP modules we can use ?
In our install (vMix HD) we are able to add 7 modules and for the 8th we get an error like: 403 - Forbidden
All modules get the stream from an Wowza server.
Thank you, Clement
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Just a guess, but using a trial / developer version of Wowza? There's connection limits
Thank you for your reply.
No. It is not that kind of limitation (we do not use the trial version).
However, in tests I noticed that in different situations the limit is changed so, at this moment my quess is the limitation comes from the Wowza server and not from vMix ..
