ClementN
#1 Posted : Tuesday, March 24, 2015 10:02:26 AM(UTC)
ClementN
Romania
Is there any limitation for the number of RTSP modules we can use ?
In our install (vMix HD) we are able to add 7 modules and for the 8th we get an error like: 403 - Forbidden
All modules get the stream from an Wowza server.
Thank you,
Clement
davesuemcbride
#2 Posted : Tuesday, March 24, 2015 5:53:10 PM(UTC)
davesuemcbride
Just a guess, but using a trial / developer version of Wowza? There's connection limits
ClementN
#3 Posted : Thursday, March 26, 2015 4:28:33 AM(UTC)
ClementN
Romania
Thank you for your reply.
No. It is not that kind of limitation (we do not use the trial version).
However, in tests I noticed that in different situations the limit is changed so, at this moment my quess is the limitation comes from the Wowza server and not from vMix ..
