Joined: 1/29/2014(UTC) Posts: 24  Location: Las Angeles, CA Was thanked: 3 time(s) in 3 post(s)
Video records fine but no audio. I tried adding audio input from a webcam and I can hear it and see the signal but the recording fader doesn't show the signal and no sound on the record. Where is the input routing for the record feed?
Joined: 9/8/2014(UTC) Posts: 244 Location: Southaven MS
Thanks: 12 times Was thanked: 26 time(s) in 21 post(s)
SKYGIF wrote:https://www.youtube.com/watch?v=CCcbH5vqHpE
Make sure your audio input (whether it is a dedicated audio input or you are using audio from camera) is "turned on". You will click the AUDIO button on the input and it will turn green. You should now see the audio in the "master level" indicator located between the Preview and Live window. Hope this helps! Tim
