SKYGIF
#1 Posted : Thursday, March 19, 2015 1:30:39 PM(UTC)
SKYGIF
Video records fine but no audio. I tried adding audio input from a webcam and I can hear it and see the signal but the recording fader doesn't show the signal and no sound on the record. Where is the input routing for the record feed?
tdurhamjr
#2 Posted : Thursday, March 19, 2015 6:09:45 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
SKYGIF wrote:
https://www.youtube.com/watch?v=CCcbH5vqHpE
Make sure your audio input (whether it is a dedicated audio input or you are using audio from camera) is "turned on". You will click the AUDIO button on the input and it will turn green. You should now see the audio in the "master level" indicator located between the Preview and Live window. Hope this helps!
Tim
Similar Topics
Version 25.0.0.34 - recording audio device 'Input' not "vmixAudio" (General Discussion)
by RickBrock 9/9/2022 4:15:24 AM(UTC)
Recorded videos only recording audio to Right channel? (General Discussion)
by Trujillo 10/5/2020 10:29:49 AM(UTC)
Recording audio delay issue (General Discussion)
by hmastet 6/9/2020 11:12:21 PM(UTC)
recording audio problem prores (General Discussion)
by pierre 9/11/2015 10:18:15 AM(UTC)
Trouble recording audio from Intensity Pro (General Discussion)
by jeisch 11/26/2011 3:46:42 PM(UTC)
Recording Audio in vMix and Flash Media Live Encoder (General Discussion)
by admin 8/17/2011 12:35:00 AM(UTC)
