lan/wlan vMix virtual capture
Rank: Guest
Groups: Guests
hi martin, is there any possibility to improve vMix virtual capture with lan/wlan support? the idea is use a second machine (lan or wlan connected) to capture video or to mix as another source, using vMix from the primary computer. i already try desktop capture but the quality is not what i expected, even max. quality is set. thank you for your attention, regards, melody www.espiritosanto.cc
