melody
#1 Posted : Tuesday, April 3, 2012 12:00:58 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
is there any possibility to improve vMix virtual capture with lan/wlan support?
the idea is use a second machine (lan or wlan connected) to capture video or to mix as another source, using vMix from the primary computer. i already try desktop capture but the quality is not what i expected, even max. quality is set.
thank you for your attention, regards,
melody
www.espiritosanto.cc
