TL68
#1 Posted : Thursday, November 26, 2026 8:28:38 PM(UTC)
TL68
Sweden
Hi all!
Just starting playing/testing/setting up some new gear and I am playing around with connecting vMix to a Behringer Wing Compact audo mixer.
One use case that may be for us is to run a video in vmix but controlling audio on a physical fader on the Wing mixer (which will have other audio sources too).
So tried this setup:
Video input in vmix ->
-> Audio sent to Bus A (Behringer Wing ASIO) ->
-> Bus A mapped on the Wing to a channel/fader ->
-> Wing Main audio out mapped to USB output on the Wing ->
-> USB audio from Wing (ASIO) mapped to a vmix Audio input ->
-> Audio input from Wing sends to vMix Master
Hope you get the setup.
Running this I get approximately 0.1 sec delay on the audio coming back to vmix. It is not optimal but not too bad.
Is this what I should expect from this setup?
Any tweaks to do?
Other setups to test to do this?
This is tested on:
HP Z8 Fury G5
Intel Xeon w5-3525 (3.19 GHz)
64 GB RAM
NVIDIA RTX5080
SSD Program: 1TB
SSD Replay: 2TB
Behringer Wing Compact running firmware v3.1.2
Behringer Wing ASIO drivers
vMix version 29.0.0.46
Thanks in advance for any input on this!
dmwkr
#2 Posted : Thursday, November 26, 2026 9:32:49 PM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
Originally Posted by: TL68 Go to Quoted Post
Hi all!
Any tweaks to do?
Not using it, but this is a case, where negative audio delay should be possible.
https://forums.vmix.com/...y-not-working#post122489
thanks 1 user thanked dmwkr for this useful post.
TL68 on 11/26/2026(UTC)
