Peter1000
#1 Posted : Tuesday, October 6, 2026 1:54:40 AM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
The successor to the SDI2OMT converter now works in both directions: SDI➔OMT/NDI and OMT/NDI➔SDI.
Automatic format detection. The project is on GitHub.
The README contains a link to the ClickOnce installer.
The program is licensed under the MIT License; please note the separately listed OMT and NDI license terms.
download here on Github
ClickOnce setup included (read.me:-)
thanks 1 user thanked Peter1000 for this useful post.
jet on 10/9/2026(UTC)
jet
#2 Posted : Thursday, October 15, 2026 3:52:08 PM(UTC)
jet
Was thanked: 30 time(s) in 28 post(s)
Great program!
Why it is called SDI2OMD CONVERTER and not SDI2OMT CONVERTER?
And I hope there will be soon OMT2SDI CONVERTER/DECODER also :)
Kind regards,
Jani
Peter1000
#3 Posted : Thursday, October 15, 2026 8:54:00 PM(UTC)
Peter1000
Switzerland
Those who can read and write are really lucky :-)
give me some time..
jet on 10/15/2026(UTC)
Peter1000
#4 Posted : Monday, October 19, 2026 12:43:38 AM(UTC)
Peter1000
Switzerland
New advanced Version update.
The new link is in the top post
The SDI-converter converts SDI signals to OMT or NDI and back again. It works with Blackmagic DeckLink cards. It works with the latest driver (16.4); older drivers may not work
If your Blackmagi card refuses to work with a new driver, you can simply install the firmware yourself.
First, install the latest Decklink driver.
Restart your computer.
Right-click on the Windows logo at the bottom of the screen, open Command Prompt as an administrator, and enter these two lines:
cd “C:\Program Files\Blackmagic Design\Blackmagic Desktop Video”
.\DesktopVideoUpdateTool.exe -a -u
Your card will then reflash itself and work immediately with the new driver.
jet on 10/19/2026(UTC)
jet
#5 Posted : Monday, October 19, 2026 4:24:03 AM(UTC)
jet
Thanks Peter for sharing this info!
And the new SDI Converter App is great! Thanks!
Guest (7)
