Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
The successor to the SDI2OMT converter now works in both directions: SDI➔OMT/NDI and OMT/NDI➔SDI. Automatic format detection. The project is on GitHub. The README contains a link to the ClickOnce installer. The program is licensed under the MIT License; please note the separately listed OMT and NDI license terms. download here on GithubClickOnce setup included (read.me:-)
 1 user thanked Peter1000 for this useful post.
Joined: 11/14/2012(UTC) Posts: 403  Location: Finland Thanks: 266 times Was thanked: 39 time(s) in 37 post(s)
Great program!
Why it is called SDI2OMD CONVERTER and not SDI2OMT CONVERTER?
And I hope there will be soon OMT2SDI CONVERTER/DECODER also :)
Kind regards, Jani
Those who can read and write are really lucky :-) give me some time..
New advanced Version update. The new link is in the top post The SDI-converter converts SDI signals to OMT or NDI and back again. It works with Blackmagic DeckLink cards. It works with the latest driver (16.4); older drivers may not work If your Blackmagi card refuses to work with a new driver, you can simply install the firmware yourself. First, install the latest Decklink driver. Restart your computer. Right-click on the Windows logo at the bottom of the screen, open Command Prompt as an administrator, and enter these two lines: Quote:cd “C:\Program Files\Blackmagic Design\Blackmagic Desktop Video”
.\DesktopVideoUpdateTool.exe -a -u Your card will then reflash itself and work immediately with the new driver.
Originally Posted by: Peter1000  If your Blackmagi card refuses to work with a new driver, you can simply install the firmware yourself. First, install the latest Decklink driver. Restart your computer. Right-click on the Windows logo at the bottom of the screen, open Command Prompt as an administrator, and enter these two lines: Quote:cd “C:\Program Files\Blackmagic Design\Blackmagic Desktop Video”
.\DesktopVideoUpdateTool.exe -a -u Your card will then reflash itself and work immediately with the new driver. Thanks Peter for sharing this info! And the new SDI Converter App is great! Thanks!
