aidancomi
#1 Posted : Friday, February 27, 2026 7:18:30 AM(UTC)
aidancomi
I'm trying to seperate select channels from my RODECaster Pro II in multitrack mode. As it stands now I can import the device multiple times and manually mute channels in the channel mixer, but with the 16 channels (8 L and 8 R) that the RODECaster sends, it can be cumbersome to do this manually for every input I need.
Is there a way to import the device with only select channels or an easier way to mute channels?
Any help is appreciated!
dmwkr
#2 Posted : Friday, February 27, 2026 8:06:31 PM(UTC)
dmwkr
Don't know the device, but usually you select a channel when adding audio input, so you have one input per channel. Make sure you have the ASIO drivers installed.
