Select channels from multichannel audio input
I'm trying to seperate select channels from my RODECaster Pro II in multitrack mode. As it stands now I can import the device multiple times and manually mute channels in the channel mixer, but with the 16 channels (8 L and 8 R) that the RODECaster sends, it can be cumbersome to do this manually for every input I need.
Is there a way to import the device with only select channels or an easier way to mute channels?
Any help is appreciated!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Don't know the device, but usually you select a channel when adding audio input, so you have one input per channel. Make sure you have the ASIO drivers installed.
