Ed Tech
#1 Posted : Wednesday, February 18, 2015 9:21:09 PM(UTC)
Ed Tech
Would it be possible to add a check box when setting up an image file that would also start and audio file. This would be very helpful to my Junior High crew, and I can't think of another way to get this done simply...but I'm to hearing from the wisdom of the vMix community. Love the product!
ask
#2 Posted : Thursday, February 19, 2015 12:05:53 AM(UTC)
ask
1. Create your video input.
2. Create an Audio input.
3. Create a shortcut to trigger the video input e.g. V
4. Create a shortcut to trigger the audio input e.g. A
5. Open one of the shortcuts.(V) Click on the Advanced tab
6. Select the other shortcut you wish to trigger (A) and ADD
7. Close and save
Now press V and both inputs start at the same time.
#3 Posted : Thursday, February 19, 2015 12:55:23 AM(UTC)
You could also use the "Triggers" feature in settings (cog wheel of input) to establish a behavior (such as turn "Audio On") every time you transition in or out of that input.
Thremir
#4 Posted : Thursday, February 19, 2015 4:48:01 AM(UTC)
Thremir
I think if both inputs auto-plays, you could make a multi-view and transistion to it, making both play at once.
