Feature Requests
Sync Audio Start with Image Sequence
Joined: 10/29/2013(UTC) Posts: 57 Location: Conroe TX
Thanks: 6 times Was thanked: 5 time(s) in 5 post(s)
Would it be possible to add a check box when setting up an image file that would also start and audio file. This would be very helpful to my Junior High crew, and I can't think of another way to get this done simply...but I'm to hearing from the wisdom of the vMix community. Love the product!
1. Create your video input. 2. Create an Audio input. 3. Create a shortcut to trigger the video input e.g. V 4. Create a shortcut to trigger the audio input e.g. A 5. Open one of the shortcuts.(V) Click on the Advanced tab 6. Select the other shortcut you wish to trigger (A) and ADD 7. Close and save
Now press V and both inputs start at the same time.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
You could also use the "Triggers" feature in settings (cog wheel of input) to establish a behavior (such as turn "Audio On") every time you transition in or out of that input.
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
I think if both inputs auto-plays, you could make a multi-view and transistion to it, making both play at once.
Feature Requests
