Play Outro Video When Ending Live Stream
I am using vMix 29.0.0.46 for my church with a HD SDI Blackmagic card for two cameras and NDI from ProPresenter for lower thirds.
We record, live stream, and output to nursery TVs at the same time. I have read how to use triggers to stop a live stream after playing a video. However, I need to play an outro video when I click to stop the live stream. I don't want the outro video to be seen on the TVs or the recording, only the live stream.
Is that possible?
So essentially, I click to end the Live Stream --> outro video plays --> live stream automatically ends after video finishes.
Thank you for your insight.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
1. Live has to use a different out then as the local stuff (Output 2) 2. If you stop live streaming you stop it. The only way I can think of is to instead create a shortcut that a) stops recording b) transitions to the outro c) a trigger is set on completion to stop streaming (might need a script)
