bholland
#1 Posted : Monday, February 16, 2026 4:13:12 AM(UTC)
bholland
I am using vMix 29.0.0.46 for my church with a HD SDI Blackmagic card for two cameras and NDI from ProPresenter for lower thirds.
We record, live stream, and output to nursery TVs at the same time. I have read how to use triggers to stop a live stream after playing a video. However, I need to play an outro video when I click to stop the live stream. I don't want the outro video to be seen on the TVs or the recording, only the live stream.
Is that possible?
So essentially, I click to end the Live Stream --> outro video plays --> live stream automatically ends after video finishes.
Thank you for your insight.
mavik
#2 Posted : Monday, February 16, 2026 5:26:07 AM(UTC)
mavik
1. Live has to use a different out then as the local stuff (Output 2)
2. If you stop live streaming you stop it. The only way I can think of is to instead create a shortcut that
a) stops recording
b) transitions to the outro
c) a trigger is set on completion to stop streaming (might need a script)
