delphiCE
#1 Posted : Friday, February 6, 2026 6:29:23 AM(UTC)
delphiCE
Turkey
Hello
Can the VMix program receive data from another application via TCP server or UDP broadcast? My goal is to send from external exe to UDP broadcast JSON to the VMix application and display it as subtitles.
mavik
#2 Posted : Friday, February 6, 2026 5:36:23 PM(UTC)
mavik
vMix does not support closed captioning inputs/outputs. But what you could do is to burn them into the video (open captioning) via a title and datasource. vMix supports JSON datasources and they can be hosted on any server.
Alternatively if you really need close captioning you could send your stream to a service and merge there with the JSON data. Services might be expensive. So check out nimble streamer that you can setup and have full control yourself.
delphiCE on 2/6/2026(UTC)
delphiCE
#3 Posted : Friday, February 6, 2026 6:06:37 PM(UTC)
delphiCE
Turkey
Thank you for reply.
If I write data to an XML file and select it as a data source, if I delete or change the data in that XML file, will the subtitles on the live stream change or disappear?
richardgatarski
#4 Posted : Friday, February 6, 2026 10:23:16 PM(UTC)
richardgatarski
yes, as you can see in
Note though, as mavik says, vMix does not support closed captioning.
mavik
#5 Posted : Friday, February 6, 2026 11:16:49 PM(UTC)
mavik
They will update once the xml updates.
You can try with a simple csv file. open it in an editor and change stuff. Once you press save vmix takes the updates.
BeverlyMoore
#6 Posted : Thursday, February 12, 2026 11:46:05 PM(UTC)
BeverlyMoore
Potresti utilizzare un file di testo aggiornato automaticamente oppure un'API supportata per mostrare i sottotitoli in tempo reale. Nel tempo libero alcuni preferiscono Gioca ora su Naobet Italia. Ognuno ha il proprio modo di rilassarsi.
Thanks for the video.
