Hardware Compatibility
AJA Corvid 88 for Key/Fill Input
Joined: 11/13/2021(UTC) Posts: 3  Location: Atlanta, GA Thanks: 1 times
I'm aware that I cannot do key/fill output from Vmix using the Corvid card.
I am wondering - is it possible to ingest a key/fill graphics input for use as an overlay using the Corvid 88 card?
Joined: 10/31/2020(UTC) Posts: 197  Thanks: 6 times Was thanked: 44 time(s) in 43 post(s)
Originally Posted by: ThomasWallis  I'm aware that I cannot do key/fill output from Vmix using the Corvid card.
I am wondering - is it possible to ingest a key/fill graphics input for use as an overlay using the Corvid 88 card? vMix supports key/fill input. Add the key and fill as two separate inputs. Then, on the "fill" input, go to settings, then color key, then there's an option for "key/fill input" where you can select your other input as the key.
