ThomasWallis
#1 Posted : Thursday, February 5, 2026 4:42:20 AM(UTC)
ThomasWallis
I'm aware that I cannot do key/fill output from Vmix using the Corvid card.
I am wondering - is it possible to ingest a key/fill graphics input for use as an overlay using the Corvid 88 card?
kross
#2 Posted : Thursday, February 5, 2026 5:03:05 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
vMix supports key/fill input. Add the key and fill as two separate inputs. Then, on the "fill" input, go to settings, then color key, then there's an option for "key/fill input" where you can select your other input as the key.
