burie
#1 Posted : Monday, January 5, 2026 2:20:00 AM(UTC)
burie
Germany
Hi!
I am looking for a way to switch the routing of some audio channels via Hotkey/MIDI-Hotkey.
What is the right name of the function in my shortcut-settings?
Until now I am able to fade the volume with my midi mixer, but I'd like to mute the channel per key (red framed), switch the routing to output Channel A,B,D and E
The only option I found is to turn it "solo" (yellow framed)
thanks for your help.
#2 Posted : Monday, January 5, 2026 5:06:42 AM(UTC)
@ burie
If I understand you correctly, the Shortcuts to use are:
AudioBus (toggle)
AudioBusOn
AudioBusOff
where the Value = the desired Bus (M/A/B/C/D/E/F/G appropriately)
burie
#3 Posted : Monday, January 5, 2026 5:50:04 AM(UTC)
burie
Germany
Originally Posted by: IceStream Go to Quoted Post
@ burie
AudioBus (toggle)
AudioBusOn
AudioBusOff
...but there is no opportunity to set the Bus you like
no bus option.jpg (21kb) downloaded 96 time(s).
There is ONE option... SetVolumeBusMixerA... there I could set the volume to send to Bus A, but I can only mute this volume, but the A button keeps his "ON" light, and this is a little bit confusing to handle if you cannot see the status of channel A
I should say... I have vmix 4k 27.0.0.91... could somebody say if there are some changes in newer versions?
I wanna move to vmix 29, its prepared on a new Win11 machine.
dmwkr
#4 Posted : Monday, January 5, 2026 8:50:28 PM(UTC)
dmwkr
Was thanked: 160 time(s) in 144 post(s)
Your screenshot shows the correct shortcut function, but there is the "Value" field missing below the "Verknüpfung zur Input-Nummer zuweisen" checkbox. Don't know why. Is this field also missing with other functions that demand a value? Maybe try a clean re-install of vMix. This functionality should also be available in your version.
burie
#5 Posted : Wednesday, January 7, 2026 2:32:04 AM(UTC)
burie
Germany
yep, there are many other functions where I think that a value input is needed but not visible.
i.e.
SetBusAVolume (not needed if you use a midi-fader, but if you wanna usw a key...)
SetVolume (no value for volume, only input select)
SetBalance (same)
AudioBusOn (only input select, but no value for Bus number)
and all related shortcut functions
dmwkr
#6 Posted : Wednesday, January 7, 2026 2:56:45 AM(UTC)
dmwkr
I'd try a re-install, make sure to close all other software. If it does not help, contact vMix support directly:
https://www.vmix.com/contact-us.aspx
burie
#7 Posted : Wednesday, January 7, 2026 9:23:25 AM(UTC)
burie
Germany
let's wait for the new streaming PC to be used, it's almost ready and will have vmix 29 then. On the current PC, I don't do much work anymore.
burie
#8 Posted : Monday, October 26, 2026 4:43:13 PM(UTC)
burie
Germany
Now it is a fact... the problem is the same on my new PC with the current version of vMix as well as on my current PC w2ith the same version.
So I think I will contact the support team directly because it doesnt feel like they are reading here.
