Switch Audio Routing per channel
Joined: 2/18/2019(UTC) Posts: 59  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
 channelroutingswitches.png (35kb) downloaded 110 time(s).Hi! I am looking for a way to switch the routing of some audio channels via Hotkey/MIDI-Hotkey. What is the right name of the function in my shortcut-settings? Until now I am able to fade the volume with my midi mixer, but I'd like to mute the channel per key (red framed), switch the routing to output Channel A,B,D and E The only option I found is to turn it "solo" (yellow framed) thanks for your help.
@ burie
If I understand you correctly, the Shortcuts to use are: AudioBus (toggle) AudioBusOn AudioBusOff where the Value = the desired Bus (M/A/B/C/D/E/F/G appropriately)
Originally Posted by: IceStream  @ burie If I understand you correctly, the Shortcuts to use are: AudioBus (toggle) AudioBusOn AudioBusOff where the Value = the desired Bus (M/A/B/C/D/E/F/G appropriately)
Ice ...but there is no opportunity to set the Bus you like  no bus option.jpg (21kb) downloaded 96 time(s).There is ONE option... SetVolumeBusMixerA... there I could set the volume to send to Bus A, but I can only mute this volume, but the A button keeps his "ON" light, and this is a little bit confusing to handle if you cannot see the status of channel A I should say... I have vmix 4k 27.0.0.91... could somebody say if there are some changes in newer versions? I wanna move to vmix 29, its prepared on a new Win11 machine.
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Your screenshot shows the correct shortcut function, but there is the "Value" field missing below the "Verknüpfung zur Input-Nummer zuweisen" checkbox. Don't know why. Is this field also missing with other functions that demand a value? Maybe try a clean re-install of vMix. This functionality should also be available in your version.
Originally Posted by: dmwkr  Your screenshot shows the correct shortcut function, but there is the "Value" field missing below the "Verknüpfung zur Input-Nummer zuweisen" checkbox. Don't know why. Is this field also missing with other functions that demand a value? Maybe try a clean re-install of vMix. This functionality should also be available in your version. yep, there are many other functions where I think that a value input is needed but not visible. i.e. SetBusAVolume (not needed if you use a midi-fader, but if you wanna usw a key...) SetVolume (no value for volume, only input select) SetBalance (same) AudioBusOn (only input select, but no value for Bus number) .... and all related shortcut functions
Originally Posted by: dmwkr  let's wait for the new streaming PC to be used, it's almost ready and will have vmix 29 then. On the current PC, I don't do much work anymore.
Originally Posted by: dmwkr  Now it is a fact... the problem is the same on my new PC with the current version of vMix as well as on my current PC w2ith the same version. So I think I will contact the support team directly because it doesnt feel like they are reading here.
