carl.cut4th
#1 Posted : Tuesday, December 23, 2025 2:40:08 AM(UTC)
carl.cut4th
Good day, and Happy Holidays to everyone —
I’m hoping someone can clarify whether it’s possible to append a Title.gtzip input from one vMix project into another while keeping the Data Source assignments intact. When I append a Title.gtzip from a different project, the Title Editor’s Data Source field resets to None, even though the same Data Source is fully configured in both projects.
This becomes a real challenge because many of our Title.gtzip files contain 200+ individual data bindings. Reassigning each one manually is doable, but extremely time‑consuming, and it makes sharing Title.gtzip assets between projects far less practical. If anyone has insight, a workaround, or can confirm whether this is expected behavior, I’d greatly appreciate the guidance.
Best regards,
Carl
#2 Posted : Thursday, December 25, 2025 2:59:57 PM(UTC)
@ carl.cut4th
The "Append" feature allows you to bring the Input over, but none of its settings (which includes Data Source mappings):
- https://www.vmix.com/help29/OpenPreset.html
You would be best to open the Preset itself and then modify it appropriately for your current project (or "Append" it and remap the Data Sources).
