JohnNorris92
#1 Posted : Tuesday, December 16, 2025 9:00:44 PM(UTC)
JohnNorris92
New Zealand
It would be great to have the option to "Export All Camera Angles" when exporting replay events. So you can highlight all clips and export all the angles for every event, rather than having to tick every angle for every event.
Also a Pre / Post "Handle Length" or something to export every clip with a few extra seconds on the top and bottom of each clip/angle.
peachyclerk
#2 Posted : Tuesday, December 30, 2025 7:29:23 PM(UTC)
peachyclerk
American Samoa
Instead of having to check every viewpoint for every event, you may highlight every clip and export every aspect for every event.
#3 Posted : Wednesday, December 31, 2025 12:42:02 AM(UTC)
A current workaround is to use a vMix script (vb.net) to loop through all events and set all cameras on
same applies for adjusting a Pre / Post extra time
all functions needed are available to do so
It still will only export only the camera angles that are set
Similar Topics
Keep last settings when exporting replays (Feature Requests)
by TL68 3/5/2024 7:47:13 PM(UTC)
