It would be great to have the option to "Export All Camera Angles" when exporting replay events. So you can highlight all clips and export all the angles for every event, rather than having to tick every angle for every event. Also a Pre / Post "Handle Length" or something to export every clip with a few extra seconds on the top and bottom of each clip/angle.
Joined: 12/30/2025(UTC) Posts: 1  Location: United States
Instead of having to check every viewpoint for every event, you may highlight every clip and export every aspect for every event.
Joined: 12/27/2012(UTC) Posts: 5,515  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: JohnNorris92  It would be great to have the option to "Export All Camera Angles" when exporting replay events. So you can highlight all clips and export all the angles for every event, rather than having to tick every angle for every event. Also a Pre / Post "Handle Length" or something to export every clip with a few extra seconds on the top and bottom of each clip/angle.
Thanks A current workaround is to use a vMix script (vb.net) to loop through all events and set all cameras on same applies for adjusting a Pre / Post extra time all functions needed are available to do so Originally Posted by: peachyclerk  Instead of having to check every viewpoint for every event, you may highlight every clip and export every aspect for every event. It still will only export only the camera angles that are set
