Instant Replay
"ReplayAngleOnOff" Shortcut
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
While testing the new replay I felt the need for another shortcut. "ReplayAngleOnOff" would activate/deactivate the checkbox each camera has. So you don't have to use the mouse and just create 4 shortcuts to switch each angle on/off. In my opinion this shortcut should do this for the current selected highlight. With "value" you select the angle. Regards, Yannick
Rank:: Advanced Member
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Yes this could be great also. I was thinking four shortcuts but if it is possible to navigate events and angles separately it makes sense that you could have one button to mark on off the selected item. Then we need up and down (there is already) and left and right buttons. Though I still think that fastest way (little different thing also) could be four shortcuts to immediately play the the corresponding angle of the selected event to the output. So not to mark/tick the angle but instantly play it. This way it is possible to decide the order of the angles on the fly.
These all above shortcuts could exist together. So many ways and situations to do things :)
Instant Replay
