samirbridi
#1 Posted : Tuesday, October 28, 2025 3:22:53 AM(UTC)
samirbridi
Brazil
An alternative that I believe is even cleaner for the software is, instead of using a dropdown to select the audio files (only those that are in the list), why not make a mark for the audio you want or even an on/off button. This would be much easier.
You could even use what already exists, which is already in the audio mixer, just bring it into the other options
WaltG12
#2 Posted : Tuesday, October 28, 2025 4:35:22 AM(UTC)
WaltG12
I'm not following, nor do I necessarily understand what you're referencing.
samirbridi
#3 Posted : Tuesday, October 28, 2025 4:46:56 AM(UTC)
samirbridi
Brazil
The audio selection in SRT, for example, is like this... in short, there are only these defined options
My suggestion is to have, for example, free user choice, like this.
MfisherTSN
#4 Posted : Tuesday, October 28, 2025 10:44:11 AM(UTC)
MfisherTSN
Canada
I am looking to do the same sort of thing to output different language feeds of an event. The External Outputs options are limited. Is there any way to change this?
VMIX BUSES
M A B C D E F G
EXT 1 I.S. Lang 1 LFE Mix
EXT 2 I.S. Lang 2 LFE Mix
EXT 3 I.S. Lang 3 LFE Mix
EXT 4 I.S. Lang 4 LFE Mix
EXT1 ABFG - English
EXT2 ACFG - French
EXT3 ADFG - German
EXT4 AEFG - Spanish
