Feature Requests
Improve audio channel selection
Joined: 10/27/2020(UTC) Posts: 38  Location: Porto Alegre Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
An alternative that I believe is even cleaner for the software is, instead of using a dropdown to select the audio files (only those that are in the list), why not make a mark for the audio you want or even an on/off button. This would be much easier.
You could even use what already exists, which is already in the audio mixer, just bring it into the other options
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
I'm not following, nor do I necessarily understand what you're referencing.
The audio selection in SRT, for example, is like this... in short, there are only these defined options  My suggestion is to have, for example, free user choice, like this.
I am looking to do the same sort of thing to output different language feeds of an event. The External Outputs options are limited. Is there any way to change this?
VMIX BUSES M A B C D E F G EXT 1 I.S. Lang 1 LFE Mix EXT 2 I.S. Lang 2 LFE Mix EXT 3 I.S. Lang 3 LFE Mix EXT 4 I.S. Lang 4 LFE Mix
EXT1 ABFG - English EXT2 ACFG - French EXT3 ADFG - German EXT4 AEFG - Spanish
Feature Requests
