Merge works on mix 2 but merge transition out cuts
Joined: 9/21/2018(UTC) Posts: 23 Location: United Arab Emirates
We've been doing sub mixes and we've noticed that mix 2 will merge properly on transition in but merge out just cuts. Any idea on why this behavior exists?
Joined: 5/15/2022(UTC) Posts: 19  Location: Ohio Was thanked: 2 time(s) in 2 post(s)
For merge to work properly, the exact same source must be in preview and in program. Merge does a transition as long as some or all of the inputs are the same. So if you have a box effect on program, when merging, have inputs used in preview. Otherwise you just get a dissolve.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I also highly recommend moving the layers accordingly so that the input to merge is at the top. Otherwise it can look weird.
