gostreamworks
#1 Posted : Thursday, September 18, 2025 9:57:54 PM(UTC)
gostreamworks
We've been doing sub mixes and we've noticed that mix 2 will merge properly on transition in but merge out just cuts. Any idea on why this behavior exists?
SDKUCSS
#2 Posted : Saturday, September 20, 2025 11:27:25 PM(UTC)
SDKUCSS
For merge to work properly, the exact same source must be in preview and in program. Merge does a transition as long as some or all of the inputs are the same. So if you have a box effect on program, when merging, have inputs used in preview. Otherwise you just get a dissolve.
mavik
#3 Posted : Monday, September 22, 2025 7:52:23 PM(UTC)
mavik
I also highly recommend moving the layers accordingly so that the input to merge is at the top. Otherwise it can look weird.
