Reply white box shortcut toggle
Hi, I’m trying to set up a shortcut in vMix that will let me toggle the white checkbox in the Replay interface — the one used to select which cameras are included in multi-angle replay output. I remember having this shortcut configured before, but I can’t recall which function I used. I’ve attached a screenshot to show exactly what I mean. My goal is to assign this toggle to a keyboard shortcut so I can quickly enable or disable cameras for multi-camera replay. Could you point me to the correct shortcut function or the best way to achieve this?  Screenshot.jpg (75kb) downloaded 25 time(s).
No need to recall or remmeber as there is a list in the documents onecan lookup ReplaySelectedEventCameraO... ReplaySeletedEventSingleCameraOn
I'll try it when i get to my computer. thank you!
