Ed789
#1 Posted : Tuesday, September 16, 2025 2:36:30 AM(UTC)
Ed789
I’m trying to set up a shortcut in vMix that will let me toggle the white checkbox in the Replay interface — the one used to select which cameras are included in multi-angle replay output. I remember having this shortcut configured before, but I can’t recall which function I used.
I’ve attached a screenshot to show exactly what I mean. My goal is to assign this toggle to a keyboard shortcut so I can quickly enable or disable cameras for multi-camera replay.
Could you point me to the correct shortcut function or the best way to achieve this? Screenshot.jpg (75kb) downloaded 25 time(s).
#2 Posted : Tuesday, September 16, 2025 2:47:21 AM(UTC)
No need to recall or remmeber as there is a list in the documents onecan lookup
ReplaySelectedEventCameraO...
ReplaySeletedEventSingleCameraOn
Ed789
#3 Posted : Tuesday, September 16, 2025 2:49:32 AM(UTC)
Ed789
I'll try it when i get to my computer. thank you!
