Feature Requests
ReplayExportSelectedEvent (API)
Currently my workflow involves frequent use of the existing "ReplayExportLastEvent" function (called via streamdeck->companion)
This is great for doing exports during a show and it's nice that it happens in the background.
Unfortunately if I need to export something other than the last event, it's a manual process.
Please consider adding an API function that does the same kind of export as "ReplayExportLastEvent" but will instead export the currently-selected replay event (or events).
Joined: 8/15/2013(UTC) Posts: 108   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
+1 for this! It would also be great to be able to export multiple events by ID via the API
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 179 times Was thanked: 3 time(s) in 2 post(s)
Feature Requests
