skidtx
#1 Posted : Sunday, September 14, 2025 4:02:58 PM(UTC)
skidtx
Currently my workflow involves frequent use of the existing "ReplayExportLastEvent" function (called via streamdeck->companion)
This is great for doing exports during a show and it's nice that it happens in the background.
Unfortunately if I need to export something other than the last event, it's a manual process.
Please consider adding an API function that does the same kind of export as "ReplayExportLastEvent" but will instead export the currently-selected replay event (or events).
aircooled76@gmail.com
#2 Posted : Thursday, September 17, 2026 9:01:44 PM(UTC)
+1 for this! It would also be great to be able to export multiple events by ID via the API
