Beta Discussion
New Overlays 5-8 Importing Stinger Settings From V28, Unable To Remove (FIXED)
Joined: 6/18/2019(UTC) Posts: 25   Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Small bug in the latest beta. When I opened my project created in V28 into the new V29, all of the new overlays (4-8) are loading with the settings for what was previously the stinger transitions.
For example: Overlay 5 loaded with a 61 frame duration, 28 Stinger Cut Point (my V28 settings for Stinger 1). These don't apply to overlays.
And because Overlay 5-8 is now not a Stinger, the form dropdown for "Stinger Input" is grayed out. So it still shows the input of the stinger - even though it's not actually triggering a stinger now - and I can't remove it.
It's not much trouble. I only had to manually change all of their settings back to default. But that greyed out dropdown might cause other issues.
Joined: 1/13/2010(UTC) Posts: 5,217  Location: Gold Coast, Australia Was thanked: 4530 time(s) in 1572 post(s)
Thanks for the report, this has now been fixed.
Unfortunately the fix will cause settings for Overlay5-8 or Stinger5-8 in presets created already in 29 to get mixed up and require re-setting, but this fix will allow all previous release presets to work correctly now.
Beta Discussion
