Beta Discussion
New Overlays 5-8 Importing Stinger Settings From V28, Unable To Remove (FIXED)
Joined: 6/18/2019(UTC) Posts: 27   Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Small bug in the latest beta. When I opened my project created in V28 into the new V29, all of the new overlays (4-8) are loading with the settings for what was previously the stinger transitions.
For example: Overlay 5 loaded with a 61 frame duration, 28 Stinger Cut Point (my V28 settings for Stinger 1). These don't apply to overlays.
And because Overlay 5-8 is now not a Stinger, the form dropdown for "Stinger Input" is grayed out. So it still shows the input of the stinger - even though it's not actually triggering a stinger now - and I can't remove it.
It's not much trouble. I only had to manually change all of their settings back to default. But that greyed out dropdown might cause other issues.
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Thanks for the report, this has now been fixed.
Unfortunately the fix will cause settings for Overlay5-8 or Stinger5-8 in presets created already in 29 to get mixed up and require re-setting, but this fix will allow all previous release presets to work correctly now.
I tested and it's working! I only had to manually fix the stinger transition times and cut points after the latest beta update.
One bug that's still present: in the new overlays 5-8, it still retains the "old" stinger in the dropdown box, even though that dropdown is not used for the overlays (since they aren't stingers anymore). The dropdown is grayed out, so I can't remove or change what's there: it just stays locked to the old stinger input from the previous vMix version. Doesn't seem to cause any issues though.
That will likely just be an incorrect import of the stinger settings from the versions of 29 with the bug. The fix can't roll back that import unfortunately.
Beta Discussion
