kmedia
#1 Posted : Thursday, August 21, 2025 3:21:06 AM(UTC)
kmedia
Small bug in the latest beta. When I opened my project created in V28 into the new V29, all of the new overlays (4-8) are loading with the settings for what was previously the stinger transitions.
For example: Overlay 5 loaded with a 61 frame duration, 28 Stinger Cut Point (my V28 settings for Stinger 1). These don't apply to overlays.
And because Overlay 5-8 is now not a Stinger, the form dropdown for "Stinger Input" is grayed out. So it still shows the input of the stinger - even though it's not actually triggering a stinger now - and I can't remove it.
It's not much trouble. I only had to manually change all of their settings back to default. But that greyed out dropdown might cause other issues.
#2 Posted : Thursday, August 21, 2025 1:51:38 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
Thanks for the report, this has now been fixed.
Unfortunately the fix will cause settings for Overlay5-8 or Stinger5-8 in presets created already in 29 to get mixed up and require re-setting, but this fix
will allow all previous release presets to work correctly now.
kmedia
#3 Posted : Tuesday, September 2, 2025 1:00:24 AM(UTC)
kmedia
I tested and it's working! I only had to manually fix the stinger transition times and cut points after the latest beta update.
One bug that's still present: in the new overlays 5-8, it still retains the "old" stinger in the dropdown box, even though that dropdown is not used for the overlays (since they aren't stingers anymore). The dropdown is grayed out, so I can't remove or change what's there: it just stays locked to the old stinger input from the previous vMix version. Doesn't seem to cause any issues though.
#4 Posted : Tuesday, September 2, 2025 1:15:21 AM(UTC)
That will likely just be an incorrect import of the stinger settings from the versions of 29 with the bug.
The fix can't roll back that import unfortunately.
