BlackMarkerTV
#1 Posted : Friday, August 15, 2025 2:18:10 PM(UTC)
BlackMarkerTV
There is probably other people who have made this request; but since I'm new to vMix and moving from OBS - I wanted to see if there was any alternative or workaround for having a waveform visualizer. I know it may seem like a small insignificant request; but we do a lot of music related shows and use that a lot to show movement on the screen that goes with the music. Is this a feature that can be added, or is there a different way of doing this using a 3rd party?
WaltG12
#2 Posted : Tuesday, August 26, 2025 10:16:52 AM(UTC)
WaltG12
+1 for the idea of adding it to vMix
I mean, just use the OBS one. That's what I do. Stick a direct NDI output on the source itself and bring the waveform into vMix with a transparent background.
If you need the sync to be perfect, you'll have to make some tweaks.
