GT
Title TransitionIn does not work
Joined: 7/6/2021(UTC) Posts: 23   Location: Münster Thanks: 4 times
I have a problem with animated titles.
I tried the "GT title 0 the classic blue". In GT Designer everythings works well, in VMix with Overlay 1 I have no starting animation but the whole title at once. The exit animation works. The second try when activating overlay 1 nothing happens. On deactivating I get the title immediately and than the exit transition.
If somebody could help me please
@ MDB
What are your Overlay 1 settings for Transition and Duration? (if not set to "Cut", you are likely missing the Animation In built into the Title)
I got the solution from VMix-Support:
"Please click the Input's cog wheel and go to the "General" tab: - enable "Automatically Play with Transition" - disable "Automatically Restart with Transition" - enable "Automatically Pause after Transition" (this needs to be enabled for IN and Out GT Title Animations)"
GT
