MDB
#1 Posted : Friday, June 27, 2025 10:30:51 PM(UTC)
MDB
Germany
I have a problem with animated titles.
I tried the "GT title 0 the classic blue". In GT Designer everythings works well, in VMix with Overlay 1 I have no starting animation but the whole title at once. The exit animation works.
The second try when activating overlay 1 nothing happens. On deactivating I get the title immediately and than the exit transition.
If somebody could help me please
#2 Posted : Monday, June 30, 2025 7:23:22 PM(UTC)
@ MDB
What are your Overlay 1 settings for Transition and Duration?
(if not set to "Cut", you are likely missing the Animation In built into the Title)
MDB
#3 Posted : Tuesday, July 1, 2025 8:13:14 PM(UTC)
MDB
Germany
Yes, it is set to "Cut"
MDB
#4 Posted : Tuesday, July 8, 2025 8:02:37 PM(UTC)
MDB
Germany
I got the solution from VMix-Support:
"Please click the Input's cog wheel and go to the "General" tab:
- enable "Automatically Play with Transition"
- disable "Automatically Restart with Transition"
- enable "Automatically Pause after Transition" (this needs to be enabled for IN and Out GT Title Animations)"
