Joined: 10/24/2023(UTC) Posts: 3  Location: caifornia Thanks: 5 times
We have been using vmix for a while and all of a sudden when we open vmix the screens on both sides and the bottom where you select source are all blue. What can this be?
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I guess some windows updates. Check the update history and try to roll back if possible. Also use the latest vMix software.
Joined: 11/27/2023(UTC) Posts: 133  Thanks: 10 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: jas105  Hi,
We have been using vmix for a while and all of a sudden when we open vmix the screens on both sides and the bottom where you select source are all blue. What can this be? open vMix and select "Settings", on the Display tab, click on the dropdown menu, and select Charcoal8, see what happens....report back here
