jas105
#1 Posted : Friday, June 20, 2025 10:49:12 AM(UTC)
jas105
We have been using vmix for a while and all of a sudden when we open vmix the screens on both sides and the bottom where you select source are all blue. What can this be?
mavik
#2 Posted : Thursday, June 26, 2025 10:23:04 PM(UTC)
mavik
I guess some windows updates. Check the update history and try to roll back if possible. Also use the latest vMix software.
Luis70
#3 Posted : Thursday, June 26, 2025 10:33:18 PM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
open vMix and select "Settings", on the Display tab, click on the dropdown menu, and select Charcoal8, see what happens....report back here
