Instant Replay
ReplayChangeSpeed shortcut not working correctly
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Does anyone else have problems with the ReplayChangeSpeed shortcut?
When I set the value to 0.5/-0.5 or something it only jumps back and forth between 10 and 100% playback speed.
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
ReplayChangeSpeed increases or decreases the speed by the value provided. So if the speed is currently 0.5 or higher and the shortcut is 0.5, the new speed will be 1.0.
To set specific speed values use the SetRate shortcut instead.
Thanks, but it still doesn't work.
Maybe I am doing something wrong.
I have 2 shortcuts:
1. Key: Up Function: ReplayChangeSpeed Duration: 1000 Input: Replay - A 7 Value: 0.15
2. Key: Down Function: ReplayChangeSpeed Duration: 1000 Input: Replay - A 7 Value: -0.15
It still jumps between 10% and 100% playback speed when I press the Up or Down button, not in 15% steps.
And with the SetRate shortcut happens nothing at all.
Key: NumLock Function: SetRate Duration: 1000 Input: Replay - A 7 Value: 0.33
It should jump to 33% playback speed with this setting, am I right?
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Change dot to comma (0,15)
Thanks!
I could have sworn that I've already tried setting it to comma and it didn't work.
Well, now it does. Thank you!
Instant Replay
