Rinsky
#1 Posted : Thursday, February 5, 2015 8:26:43 PM(UTC)
Rinsky
Does anyone else have problems with the ReplayChangeSpeed shortcut?
When I set the value to 0.5/-0.5 or something it only jumps back and forth between 10 and 100% playback speed.
#2 Posted : Friday, February 6, 2015 7:08:09 AM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
ReplayChangeSpeed increases or decreases the speed by the value provided.
So if the speed is currently 0.5 or higher and the shortcut is 0.5, the new speed will be 1.0.
To set specific speed values use the SetRate shortcut instead.
r@wisla on 2/6/2015(UTC)
Rinsky
#3 Posted : Friday, February 6, 2015 9:02:49 AM(UTC)
Rinsky
Thanks, but it still doesn't work.
Maybe I am doing something wrong.
I have 2 shortcuts:
1.
Key: Up
Function: ReplayChangeSpeed
Duration: 1000
Input: Replay - A 7
Value: 0.15
2.
Key: Down
Duration: 1000
Input: Replay - A 7
Value: -0.15
It still jumps between 10% and 100% playback speed when I press the Up or Down button, not in 15% steps.
And with the SetRate shortcut happens nothing at all.
Key: NumLock
Function: SetRate
Duration: 1000
Input: Replay - A 7
Value: 0.33
It should jump to 33% playback speed with this setting, am I right?
r@wisla
#4 Posted : Friday, February 6, 2015 9:11:00 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Change dot to comma (0,15)
Rinsky
#5 Posted : Friday, February 6, 2015 9:41:22 AM(UTC)
Rinsky
Thanks!
I could have sworn that I've already tried setting it to comma and it didn't work.
Well, now it does. Thank you!
