fgolman
#1 Posted : Tuesday, May 20, 2025 10:27:22 PM(UTC)
fgolman
What does the AutoRestart API command do? I'm assuming it will restart an input if stopped at any time (versus the Restart command which just does it once on use)? So, is it actually sitting watching for an input to stop and then it will restart it on its own?
Thanks,
Fritz Golman
RadioDNA
nikosman88
#2 Posted : Tuesday, May 20, 2025 10:50:51 PM(UTC)
nikosman88
Greece
Hi. It would be perfect if it worked like you say.It would be very usefull for example for an srt source and also a trigger like "when/if stopped-->restart and do an action". Hope for vmix 29
But what it does is for the specific input to check/tick on-->meaning enable the "Automatically Restart with Transition"
fgolman
#3 Posted : Tuesday, May 20, 2025 10:52:34 PM(UTC)
fgolman
Gotcha, there was no description in the Shortcut reference.
Thanks!
Fritz Golman
RadioDNA
